Thread: Navigation VW Passat 2005
    bruce the boss's Avatar
    bruce the boss is offline Staff Sergeant
    61
    15
    i have a question about the navigation for the VW
    I downloaded this ( http://gpsunderground.com/forum/showthread.php?101-MFD2-amp-RN-S2-V7-DVD-Navigation ) and would like to use it for a VW passat 2005.
    But I'm afraid it's not working.
    The original navigation is placed on a cd on which is mentioned Blaupunkt 2006/2007 but this is not on a DVD. The navigation is RNS MFD2
    Am I correct that the above is not for my car and that I have to look for another version (is there another version?)?
    Re: Navigation VW Passat 2005
    Since the title of the post clearly states that the update is intended for the MFD2/RN S2 DVD version it seems to me extremely daft to attempt to use it on a CD version
    You can hardly expect to be advised better than this
    And no of course it is not intended for your unit and no there is no way nor reason to unlock your unit since it already reads copies albeit with some difficulty
    61
    15
    Thanks for your clear answer.
    So there is only one option for me and that's to use these maps?
    It's hard to imagine what is going on in your brain but no one ever suggested that TravelPilot Non DX maps would be suitable for your Passat MFD2 2005
    That system has not een fitted into any car after 2000
    So even the thought is rather ridiculous
    You just take the travelPilot DX CD's
    http://gpsunderground.com/forum/show...10-2011-is-out
    You should consult the search function instead of trying to obtain an answer after random remarks about possible solutions
