Thread: tweaks for volkwagen Navigation CY
    koenh is offline Lance Corporal
    I just got a new car with the 'Volkswagen Navigation CY' GPS in it.
    I was wondering if it was possible to use an SD card to do some tweaks:
    * changing the voice
    * add POI
    Allready thanks
    Re: tweaks for volkwagen Navigation CY
    The CY system is better know as RNS510/810
    You cannot use the SD card slot for anything else than play music from MP3 files etc
    If you want to changes voices you are completely out of luck No possibility whatsoever without writing your own firmware and possibly bricking the unit forever.
    With regad to POI's there are 2 programs that can be of help:
    POI-Inspector and Pimp-My-Nav
    Both progrmas can only be used after a payed registration
    The first is specially developed for the RNS510/810 systems and has the better qualifications and very extensive possibilities
    The latter is more widely usable for all VDO Siemens navigation systems
    Thanks for the info!
    I found the 'pimp-my-nav' application, but cannot find anything about 'POI instector' (or must that be 'POI-inspector'?)
    Allready thanks to give me a link to that last program.
    grz
    have a look at this site
