Thread: Loss of speed limit sign
    mmolvid is offline Paid Member
    Since installing the V7 East map (living i sweden) I have lost the speed limit marking on the top right corner on the map page. Has this got something to do with the new map?
    I am using FW 2660 could that be the problem?
    I am also wondering what RNS 510 model type i could possibly have (A, B or C model) on my passat manufactured in spring of 08?
    All help is highly regarded!
    Re: Loss of speed limit sign
    Disappearance of the speed limit data is due to removing some attributes of the road data by the map supplier Navteq
    Whether this has been done on purpose is not known,
    I have noticed numerous other occasions where the same has occurred
    I am inclined to think that Navteq has made another of their numerous blunders!
    You will probably have an A or B model
    I have now found out that the speed limit data has not disappeard totally, it is still there on the "major" roads, just not on the small ones like i V 6.1
    The reasoning for removing it from the other roads are strange, I am at a total loss to this resaoning...
    Jan 2011
    Quote Originally Posted by mmolvid View Post
    I have done the same observation here in Denmark. Very strange to remove such a feature. This is a feature all low cost nav systems has as a standard.
    Rgd.
    Carsten
    Due to an obvious error made by Navteq in their Q4/2009 database, all publications for Siemens VDO based navigation units seem to suffer from this blunder.
    You will also appreciate that neither Navteq nor the OEM will admit that such an error was made!
    Jayro is offline Lance Corporal
    I did a thorough check of map V7 (ver 7343 from here) on my "C" unit with FW 2680 and in my neck of the woods "Scotland" the speed limit sign appears to be ok on Motorways, "A" roads and "B" roads as it was before in map ver 6.1.
    I would say it is reacting quicker to changes in the speed limit with this version ( within 10 meters of the sign)
