Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Like Tree3Likes
Thread: Firmware 3810/3814/3816/3818
  1. #21
    zisgeo is offline Staff Sergeant
    Greece
    72
    Re: Firmware 3810/3814/3816/3818
    roki199 let me make a guess: when you were getting the message "no route recommendation for this Destination", you were using map 7420 correct? cause i had the same problem. but then i used map 7388, with 3810 sw and all worked like a charm. i think that 7420 is not fully cooperating with 3810. also, i tried your suggestion and it worked too!
  2. #22
    roki199 is offline Corporal
    27
    Quote Originally Posted by zisgeo View Post
    Yes correct
  3. #23
    metalzavod is offline Sergeant
    57
  4. #24
    Greece
    72
    Quote Originally Posted by roki199 View Post
    Yes correct
    i will try the new sw 3930 to see if this problem still exist and let you know
  5. #25
    27
    waithing for feedback
  6. #26
    57
  7. #27
    Issue: after upgrading a B revision unit to SW 3810 (now the sw revision of the unit is D), the 9 bytes Coding of the module 37-Navigation DOES NOT WORK anymore (if you would try to save any 9-byte New Coding value you'll get the following error from VCDS: "Coding rejected, Error 31: request out of range")
    Solution: right before saving the New Coding value (using the Do It button) you should manually add a 10th byte (with value 00) at the end of the New Coding textbox. ONLY AFTER THAT press Do It to save the changes.
    9 byte coding (for units having A/B/C SW revisions):
    020104000400001100
    10 byte coding (for units with D SW revision):
    02010400040000110000
  8. #28
    lukynodc is offline Private
    Jan 2013
    hi guys, please have someone working link fw 5810 or upload it. Thank you in advance.
  9. #29
    jomafi's Avatar
    jomafi is offline Second Lieutenant
    Jul 2011
    Rottweil, Germany
    347
    19
    Quote Originally Posted by lukynodc View Post
    Firmware 5810 doesn't exist yet. Maybe in the future, i think on 2017
    lukynodc likes this.
    B.R. Jomafi
  10. #30
    Jan 2013
    I'm sorry, I think 3810, I be pudding
