Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree3Likes
Thread: Firmware 3810/3814/3816/3818
    metalzavod is offline Sergeant
    57
    RNS 510
    File info :
    Software Loading CD for CP2 based units
    (c) CONTINENTAL Wetzlar
    CdTreeBuilder version 3.06 is used.
    #CD:P 0 0 5 . 1 5 7 . 3 0 1
    #DATE:2010-11-26
    #Project: VWRNS
    #Author: RoNe
    #Steckbrief: C_EU_10.342_t1 C10/C6
    #CommentStart:
    This is a SWL CD for VW delivery.
    #CommentEnd:
    #Integrationphase: Delivery cw22/11 C10/C6-samples
    #VwSwPartNumber:1T0035680D/1T0035680D/7L6035680C/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G
    #VwSwIndex:3810/3816/3810/3818/3814/3810/3810
    #AppsBuild:C_EU_10.342_t1 C10/C6
    #CRC16:83a8
     http://rapidshare.com/files/438211631/FW3810.part1.rar
     http://rapidshare.com/files/438333993/FW3810.part2.rar
     http://rapidshare.com/files/438337409/FW3810.part3.rar
     http://rapidshare.com/files/438342217/FW3810.part4.rar
     http://rapidshare.com/files/438346634/FW3810.part5.rar
     http://rapidshare.com/files/438343574/FW3810.part6.rar
    RNS-510 Software 3810 for A/B/C
    http://www.megaupload.com/?d=4XT50LRD
    zisgeo is offline Staff Sergeant
    Greece
    72
    Re: Firmware 3810/3814/3816/3818
    this will change your rns part number from C to D. mine was changed from 1T0035680C to 1T0035680D. Also the log on screen and when you press setup for long time you get the following menu:
    FM
    AM
    VERSION INFO, about map, sw, hw and type of map(ex. EAST EUR).
    57
    DVD-Free not remove ...
    Greece
    72
    we can find all the firmwares for RNS510 gathered at the following link:
    May be if anybody has fast internet connection can make in this forum something similar
    57
    Unlike 3800 to 3810 is that 3810 updates Appliances "soft" (format only screw dvd-free software and other settings remain) 3800 extinguishes Appliances tightly (to be clean as a plant)
    djfreeway is offline Private
    Dec 2010
    Will this one remove DVD-Free enabled by RNS Manager?
    With this firmware still works the sequence of keys to unlock the (I + Tone) images of the DVD in motion ?
    dog likes this.
    Greece
    72
    Quote Originally Posted by mixio60 View Post
    describe how to do it and i will try, since i am using this hw.
    Greece
    72
    strange thing! although, when you press setup for a long time, it says T0035680D, when i check it with vcds it still says T0035680C as HW
    Dec 2010
    Because the update just changes the SW Part-No.
