Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Like Tree7Likes
Thread: Rns 510 western europe v7.1
    zisgeo is offline Staff Sergeant
    Greece
    72
    Rns 510 western europe v7.1:
    Continental Automotive GmbH
    I IC RD G SW NM DB
    Content
    Volume: CD_7388
    Date: 13.10.2010
    db: EU(2009Q4)
    Area: West Europe
    Supplier: Navteq
    Version: 505.20.942.9.84
    Customer: 1627387139
    Customer Info: VW
    Features: V10
    TPD: 2010107003
    SVD: EDB_20101013080456_62
    TMC: 20101006
    Phoneme: yes
    DBAL: V5.18 V6.28 V7.20
    V: 505.20.942.16.84
    http://linksave.in/5169571764d7fc19aec1da
    The DVD has the new format of poi in file EDB and can be used with fw 38**
    JoeZG, dubbellfris, solviv and 3 others like this.
    turbox's Avatar
    turbox is offline Private
    22
    Re: Rns 510 western europe v7.1
    This version is incomplete, no Italian and other language for SDS.
    The original is on DVD DL, this is special for standard DVD.
    Quote Originally Posted by turbox View Post
    It is of course very clever to remove some of the unnecessary SDS files in order to fit the image to a DVD5
    If you require a specific language than it is easy to substitute any of the other languages.
    Dec 2010
    22
    My copy was having a few errors, saying "CD/DVD problem - please load NAV DVD". This is coming sporadicly, but it is copying the DVD anyway. Seems to be working well also.
    Norwegian SDS is not included, don't know if this is removed or if it was there at the beginning.
    The errors might be from my choice of DVD or maybe also DVD burning.
    If you do not use the 38XX software it is unnecessary to use the 7.1 editions
    Anyway, the V7 editions at least include all the POI's and speedcams so you can forget about 7.1
    SDS languages available
    Czech, English, German, French, Italian, Spanisch, Portuguese, Dutch
    Greece
    72
    Quote Originally Posted by kristofferstranden View Post
    for Norwegian SDS, please follow gazo's info mentioned upper.
    for the CD/DVD problem - please load NAV DVD, i believe that you should burn the dvd again in low speed. it is said that *4 is good solution but i prefer *2.5. when the burning is done, ask for verification of written data to see if any error's occured. good luck
    lamula1 is offline Corporal
    23
    22
    One question: Is this a BETA version V7.1?.
    Greece
    72
    all of fw 38** and map CD_7388 and CD_7420 (west eur and east V7.1 ) are beta. if you do not want to use beta stay at V7.0 and fw 27**
    Dec 2010
    Quote Originally Posted by lamula1 View Post
    Yes, the CD_7388 is a beta and a prerelease. The CD_7420 is going to be the V7.1 East and the CD_7419 will be the V7.1 West...
    I IC RD G SW NM DB
    Content
    Volume: CD_7419
    Date: 26.11.2010
    db: EU(2009Q4)
    Area: West Europe
    Supplier: Navteq
    Version: 505.20.943.4.84
    Customer Version: V7.1
    Customer Info: VW
    Features: V10
    TPD: 2010087006
    SVD: EDB_20101125140258_62
    TMC: 20101006
    Phoneme: yes
    Jan 2011
    are the pois in new format the all the latest pois of v.7? or they hae just a few of them as trial of the new version?
  1. 14th March 2012, 06:37
  2. 12th January 2012, 14:27
  3. 22nd August 2011, 15:55
  4. 16th August 2011, 07:03
  5. 4th August 2011, 12:37
  6. 14th July 2011, 13:14
  7. 14th July 2011, 08:38
  8. 26th June 2011, 14:00
  9. 26th June 2011, 13:44
  10. 21st May 2011, 21:01
  11. 20th May 2011, 17:33
  12. 14th May 2011, 13:48
  13. 11th May 2011, 19:12
  14. 3rd May 2011, 21:56
  15. 3rd May 2011, 20:28
  16. 2nd May 2011, 15:46
  17. 15th April 2011, 16:11
  18. 7th April 2011, 08:09
  19. 11th March 2011, 10:16
  20. 24th February 2011, 12:35
