Results 1 to 10 of 13
Like Tree2Likes
Thread: rns510.poi.inspector.v5.1.3beta
    metalzavod is offline Sergeant
    57
    For DVD RNS510 map V7.1
    RELEASE 5.2rc NEW VERSION
    Summary of features related to db3 custom POI
    [general]
    - new DB - creates new predefined custom poi database (many custom already icons included)
    - open any selected custom poi DB
    - browse through different languages when avail
    [categories]
    - add new
    - modify (change name or icon)
    - delete (when empty)
    - reorganize (drag & drop in tree)
    [POIs]
    - import from asc,gpx,kml,ov2 (asc can import extra field - phone,country,city...explained below)
    - set addtion info (map zoom level...)
    - delete all pois from category - clean category
    - check each poi on map
    [tools]
    - add custom icons (single icon or mass PNG import from selected folder)
    ASCII format description
    Supported format: separator [,] - string quote ["] (optional) - character [;] at begining of the line = comment, this line is ignored
    lon,lat,name name1,country,region... | lon,lat,"name, name1","country", region...
    Supported fields: lon,lat,name,country,region,city,street,house#,pho ne#
    Example: 14.443444, 50.050892, "Speed cam, 50kmh", UK, ,London, a Street, 2118, 005221454787
    letitbit.net
    PersonalPOI_Quick_Start_Guide_v1.0
    DOWNLOADS
    v5.1.3beta old version
    + Add/edit/delete/organize categories
    + Import POIs (supported all formats from prev version)
    + Delete all POIs from category
    [UPDATE]
    Version is ready for download 5.1.3beta
    + Preloaded big iconset for newDB
    ToDo:
    * Custom icon maintain
    * Support for languages
    * Importing additional info (phone,streed, etc) when avail in source file
    * POI warning (if navi fw use this feature - not sure yet)
    letitbit.net
    masuni likes this.
    Feb 2011
    Re: rns510.poi.inspector.v5.1.3beta
    Hi,can you explain how to use it with POI.DB3.
    I have error when import new poi
    There is a blogspot on this subject
    Please go there
    57
    Quote Originally Posted by ryou View Post
    discussion here
    Jan 2011
    can you explain me how to put the file on the SD card db3. I see nothing RNS
    please
    57
    Quote Originally Posted by azchz View Post
    please
    See **HOT** New RNS510 POI inspect0r v3.0
    roki199 is offline Corporal
    28
    zisgeo is offline Staff Sergeant
    Greece
    72
    according to the pdf file, if you change the zoom level of the poi to 1500, you are supposed to have them on screen at zoom level 150m. i tried that, but it only shows poi in zoom level 25m. have anybody else faced that or knows what is going on?
    ch061441 is offline Corporal
    19
    FW 3890 installed, new Maps V7.1 7420 installed, POI.DB3 with Poinspector created and imported, all is working fine (3D) I have my Pois. (with zoom level 40000 for 400 m)
    I hope Alerting is comming soon.
    Regards.
    Manuel
    Greece
    72
    i noticed that with zoom level 15000 for 150 m, your poi's are shown in zoom level 150m and lower(125m - 100m- 75m- 50m- 25m), but not above that level. So, if we put zoom level 400.000, we will have the poi's shown in all levels till 400m
    David Webster likes this.
  1. 13th February 2012, 17:33
  2. 23rd December 2011, 06:40
  3. 21st July 2011, 20:05
  4. 10th April 2011, 07:10
  5. 3rd March 2011, 21:02
